Wabash Transfer Molding help
I am not super knowlegable on Transfer molding presses. I have a Wabash Tranfer Press
Model VT 75H-24-x
It is a vaccum assist process and vertical clamping where you add resin wafers on top
I am running: Hysol MG18 it is a transparent epoxy molding compound, developed specifically for the encapsulation of
optoelectronic devices..
If anyone knows about these machines I am getting a super low yield manly due to bubbles. I have no idea where to start looking. There are yeild variances operator to operator but is there anything I can do from a processing stand point??
Link to actual press I need your help on...
http ://www.wab ashmpi.com /transfer_ molding_pr esses.html
Model VT 75H-24-x
http
RE: Wabash Transfer Molding help
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
I have used a Wabash to mold hypalon rubber. The biggest issue that I had was non-fill due to the mold gates not being large enough.
Try less injection pressure and longer cycle time, that will reduce the chance of air entrapment.
You may also want to look at the load in the transfer pot - one thick slab of material will give less places for air to be entrapped than many smaller chunks or wafers.
Pat
for site rules
