Achieving hardness on en36
how can we achieve HRC 50 on EN36 of Diameter 40 MM so as it does not become brittle.
RE: Achieving hardness on en36
EN36 is a case hardening steel . Popularly used for gears, sprockets etc. You will not achieve those hardness at the core .
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
Is water quenching appropriate given it's low C? Just curious, not my thread.
i require case hardening only but the material should not become brittle.
I have rarely seen them water quench. It is always oil quenched . It is very unlikely that with a carbon of around 0.15% it is possible to get RC50 in the core(of course it does have about 3.5%Ni and Cr about 0.8%)
If this statement is correct,why did you ask for 50 RC in the core. Your question was misleading
Yes, I agree the low C won't ger 50Rc even at fully quenched condition. Very unlikely, maybe 40+ as quenched.
Sorry, wittyrohit I hacked your thread. This steel at QT condition shouldn't be brittle but maynot get 50Rc. But you can get it on surface by carburizing it.
