Temperature control valve
I am looking for valve similar to this;
http://www .danfoss.c om/Product s/Categori es/Detail/ RA/Water-V alves/AVTA -temperatu re-control led-water- valve/AVTA -pipe-thre ad-connect ions-for-n eutral-med ia/003N317 1/515fbfdf -f531-46da -9c7a-f766 3e78213c/e 3019434-64 75-4169-91 63-0392977 abf1f.html
Delivery time too long (2-4 weeks) from Danfoss in Europe.
Need it to control water temp. to 100C. Valve opens as temperature falls. 3.9 USGals./min (3.4 m^3/hr) or less.
Many thanks
http://www
Many thanks
RE: Temperature control valve
But, I'm sure Danfoss has a local distributor wherever you are. Check out this link,
http://de
avta valves are for cooling application, and they open when temperature rises.
you stated that you need valve which opens when temperature falls, and that would be avtb valves.
as and alternative you can try with:
http://www
though i am used to danfoss
