How to import images at a constant scale?
Hello everyone,
First post here, so I hope it's understandable.
I am trying to import images from ANSYS to be analysed in MATLAB. I am essentially comparing the optical properties of deformed and undeformed 2D models. Therefore, having a constant scale is important.
The problem I am having is that I can't seem to find a way to ensure that images I capture of different models are always at the same scale. As they are different sizes (for example, one may be 2mm thick, one may be 4mm thick) they will be a different sizes on screen.
Is there a way to ensure that all models will always display at the same scale?
Thanks in advance.
Thanks in advance.
RE: How to import images at a constant scale?
Just realised I made a silly mistake, I meant export not import in the above post, so sorry for that.
best
Priam
www.priamengineering.co.uk
