Building area calculations - IBC
When calculating building areas for mixed use and occupancy, are demising walls split between the two areas?
That is, if you have a CMU rectangular building with a CMU wall dividing an office area (B occupancy) from an automotive repair shop (F-1 occupancy), does the area of the shop include all of the shop exterior wall and 1/2 of the interior dividing wall (4" of CMU wall width x the length of the wall)?
RE: Building area calculations - IBC
And a demising wall (at least how I define them) can't be used as means of separating an occupancy.
Demising wall was the incorrect term. Thanks for the correction.
