Code Violation
Code Violation
The building was built in 1967 with all the supply ducts were insulated internally.
This practice is not accepted today. Anyone knows where on code books that shows this is unacceptable, please points out.
Thanks for your great help
RE: Code Violation
RE: Code Violation
if there is no such changes that requires a building permit, then there is nothing to worry about, but if there is such general repair or replace for HVAC system fore example the job should be done in accordance with the code that regulat the building area.
if you rae responsible for such job you can check with the city hall and follow thier instructions.
