Secondary effluent filtration
I would like to hear forum members experience on using single media rapid sand filtration unit (polishing) to filter municipal extended aeration secondary effluent. If a coagulant (Alum)is added, is settling before the filter a must? What is the type, size and the uniformity coefficient of the filter media used?
Thanks is advance
RE: Secondary effluent filtration
Absolutely, settlement is a must. At normal RGF flow rates of 10m3/m2 per hour at a MLSS of 3000mg/l thats 30kg of solids loading per m2 per hour. Your filter will last a matter of minutes rather than hours between washes, especially if operating contact filtration through.
Secondary effluent is the effluent from the secondary clarifier.
Filters used for secondary effluent are operated at lower flow rates than rapid sand filters, typically 1/3 less gpm/sq ft.
If you add alum, you can add the alum prior to the secondary clarifier.
You would not add an additional clarification step between the secondary clarifier and the tertiary filter.
Misunderstood in thinking you were going straight from ASP to filter with no settlement in between. Assuming a post FST solids loading of 20mg/l + whatever your hydroxide loading will be, it will work without pre-settlement, but your washing will be increased.
Suggest you should consider dual media filters(coal/sand). The coal will hold a larger quantity of solids between backwashes.
Yes you will need a coagulant if you are going to comply with PEA discharge regulations.
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
