Imperfection Command
Dear Friends
When I write  add the imperfection command to the input file
*imperfection, file=myfile
1,1
and I run the analysis in the Abaqus command prompt, it seems that the analysis doesn't continue while without adding the imperfection command to the input file everything was alright.
Does anybody know what is the problem?
RE: Imperfection Command
Problem is solved
