Welding procedures for wellhead welding
I just developed welding procedures for ASME B31 piping using ASME Section IX welding code, I'm preparing to develop the same for wellhead piping, valves which I know is API 6A. Is there a different welding code for those or will it also be covered by ASME IX as long as the filler metal and material spec requirements are met?
Thank you.
RE: Welding procedures for wellhead welding
mysarah,
Specification for Wellhead and
Christmas Tree Equipment
ANSI/API SPECIFICATION 6A
TWENTIETH EDITION, OCTOBER 2010
EFFECTIVE DATE: APRIL 1, 2011
6 Welding — General requirements
6.3 Pressure-containing fabrication weldments for bodies, bonnets, end and outlet
connections, bullplugs, valve-removal plugs and back-pressure valves
6.3.2.3 Welding procedure qualifications
The following apply:
a) written procedure:
Welding shall be performed in accordance with welding procedure specifications (WPS), written and qualified in accordance with ASME, BPVC:2004, Section IX, Article II. The WPS shall describe all the essential,nonessential and supplementary essential (if required; see ASME, BPVC:2004, Section IX) variables.
6.3.2.4 Welder performance qualification
a) testing requirements:
Welders and welding operators shall be qualified in accordance with ASME, BPVC:2004, Section IX,
Article III.
Hope that helps,
Kiwi
Thanks a lot Kiwi2671,
That means its jus the same as qualifying procedures for pressure piping under ASME IX, but the only difference if to know the material types/specs. and knowing the strenght of electrode that can serve those materials.
I would recommend reading API-6A section 6. H2S service and hardness requirements/locations, impact testing per temperature class will affect your New WPS.
Petrotrim Services
www.petrotrim.com
