Connection to X-mas tree
We need to buy a forged flange adaptor to connect to the X-mas tree.
This forge flange adaptor has the following ends
- End 1: 3" ansi/asme B16.5 flange class 2500#
- End 2: 4-1/16" API 6B flange 5ksi
And this flange adaptor shall withstand 6500 psi
Has anyone bought these kind of flange adaptor? what would it be the design code? ASME VIII??
Thanks in advance
Thanks in advance
RE: Connection to X-mas tree
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
There is a lot of information on this site and to get to some of it you have to register.
http://www.woodcousa.com/catalogs/fittings8.htm
Thank you for your answers.
It seems that we are going to make some calculations as per ASME VIII Div.2 part 5.
Unclesyd thanks for the link, that page is awesome
Petrotrim Services
www.petrotrim.com
It is the design pressure, it is not going to be the test pressure nor the working pressure.
