NX 6 - Can't copy Drafting notes containing <W@$SH_SHEET_NUMBER>
Whenever I try to copy a note in NX 6.0.4.3 that contains either <W@$SH_SHEET_NUMBER> or <W@$SH_NUMBER_OF_SHEETS> (and possibly others that I haven't tested), I get the following error message:
Enter Drafting Application
Error recovery completed for the following error:
An illegal file was given to the tag system.
Both existing notes and brand new notes behave this way as long as the text contains one of the tags I mentioned which leads me to believe those are the root cause.
RE: NX 6 - Can't copy Drafting notes containing <W@$SH_SHEET_NUMBER>
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
John R. Baker, P.E.
Industry Sector
Cypress, CA
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
So maybe if the file with the problem is saved again, the problem will go away as long as the latest version of NX6 is loaded.
