Need a favor opening a file
Hello ProE Forum,
Does anyone have software to open and save this file for me? If so, can you save as a PDF, DWG or DXF. I belive its CoCreate software.
Many Thanks,
Many Thanks,
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 5.0
Dell T5500 XP Pro SP 3 (32-bit)
Xeon CPU 2.53 GHz 3.00 GB of RAM
nVida Quadro 4000 2 GB
3D Connexion-SpaceExplorer
RE: Need a favor opening a file
Petrotrim Services
www.petrotrim.com
Best,
Mechanical Designer
Dell T5500 Windows 7 Pro (64-bit)
Xeon CPU 2.53 GHz 6.00 GB of RAM
Petrotrim Services
www.petrotrim.com
Mechanical Designer
Petrotrim Services
www.petrotrim.com
Mechanical Designer
Are you using Express 4 version?
I don't have the PDF option.
"I was able to print a PDF" ... of course!
I'm trying to find a work around to copy the geo and save it as a dwg or dxf, but the folks at PTC are pretty darn smart securing the geo. Copy and paste into Solidworks or Draftsight doesn't seem to work.
Mechanical Designer
