Power Genearation
Power Genearation
Power Genearation
I work in a manufacturing industry where we want to run the generator through 1MW steam turbine. Can someone provide any online refernece or link using which I can backwork and calculate the steam required and other inputs for turbine. (or alternatively we may have the idea of the boiler required for producing the reqd. steam).   Thanks.
RE: Power Genearation
E9
Typically in a mfr process you would first look to see if there are any waste heat sources avaialble to provide "free" energy to generate the steam , and then size the steam turbine to produce as much power as the onsite waste heat source could make.
Building your own 1 MWe power plant from scratch using normal fuels ( oil, nat gas) is rarely as competitive as  buying it from a  utility- large gas fired combined cycle plants now are over 50% efficient- it is unlikely you could match that unless you can also use exhaust steam to heat part of the existing manufacturing process .
Better areas would be- reduce energy losses ( reactance , etc)
