Automate Grouping of Sheets...
I need to be able to print (via VBA on a custom tool button) all sheets in a workbook, EXCEPT the first 2 sheets.
I can make it count the total number of sheets and tried to use:
   Dim tabcount As Integer
   tabcount = ThisWorkbook.Worksheets.Count
   Worksheets(Array(2 - tabcount)).Select
Thinking that Array(2 - tabcount) would be 2 THRU tabcount... not so apparently.
Neither did Array(2 :: tabcount) or Array(2 : tabcount) work.
I'm stuck now.  Anyone know how to make it do what I want?
RE: Automate Grouping of Sheets...
2-tabcount is "2 minus tabcount"
2::tabcount means "2 (here is a new line of VBA code) tabcount"
You can't specify a range of values for the Array function.  You have to specify each value.  Array will not work for you.  You need something like
CODE
Dim Tabcount As Long
Dim myArray() As Variant
Tabcount = ThisWorkbook.Worksheets.Count
ReDim myArray(Tabcount - 3)
For i = 0 To UBound(myArray)
  myArray(i) = i + 3
Next i
Worksheets(myArray).Select
-handleman, CSWP (The new, easy test)
