Need a favor opening a file
Does anyone have software to open and save this file for me? If so, can you save as a PDF, DWG or DXF. I belive its CoCreate software.
Many Thanks,
Many Thanks,
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 5.0
Dell T5500 XP Pro SP 3 (32-bit)
Xeon CPU 2.53 GHz 3.00 GB of RAM
nVida Quadro 4000 2 GB
3D Connexion-SpaceExplorer
RE: Need a favor opening a file
However at the moment the best I can offer is a screen shot (PNG) as this version is very limited in it's "Save as" formats.
Mechanical Designer
Mechanical Designer
Dell T5500 Windows 7 Pro (64-bit)
Xeon CPU 2.53 GHz 6.00 GB of RAM
You know what CREO stands for, right?
http://creo.amnh.org/
Mechanical Designer
There should be a link in previous post.
Anna Wood
SW2011 SP4, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
Mechanical Designer
Can't make this stuff up.
How true it is?
I would have thought the Parametic Technologies marketing would have tried a simple Google search before adopting a new name for their product.
I have them saved off here as .dxf and .dwg. I'm a reader, not an active participant. How do you want me to get these to you?
Reaper.
To post the files here, use the ...or upload your file to ENGINEERING.com link just above the Submit Post button.
Mechanical Designer
I'm showing my age, huh?
Mechanical Designer
