Breakpoint Chlorination to Control Nitrification
I am working on a project where a chloramined drinking water system is experiencing low chlorine residual in some parts.  I think that if i identify some of the sources of accelerated chloramine degradation in the system i will hopefully be able to improve the CR in the system without addition of a Booster Chlorination Station.  One problem that i think is occuring significantly in the system is nitrification, based on our water testing data, Im not sure.  Through reading all the AWWA manuals and reports i understand what can happen in systems and how it happens, but i am still having trouble with the major problem of what exactly is happening chemically in this system.
The major questions i still have are
-Where does our water system fit on the breakpoint curve? (i.e. why does our data show combined, free chlorine and free ammonia residual all together)
-Is our observed increase in nitrates/nitrites enough to be significant nitrification
-If we were to use breakpoint chlorination what steps would we have to follow to safely control the free chlorine residual.
I have included our water testing data.
I am stumped at this point any and all help will be greatly appreciated.
RE: Breakpoint Chlorination to Control Nitrification
Hi Brick583, I'm wondering if you're creating chloramines which are then being picked up in the nitrate/nitrite tests?  Superchlorination would help.  I've attached a link to the wikipedia article about chloramines.
Kevin
Take a look at lowering your pH. Nitrite/Nitrate formation will be significant above pH 9 s.u.
It is a common problem to have poor chlorine residual at dead ends in a water distribution system.
The operator of the water distribution system should be able to identify these areas.
You will still have the problem even if you use breakpoint chlorination.
