1020 Steel alternative
Our current customer has a part that's made out of 1020 Steel. We're having oxidation issues with the part. The part is shipped off for some outside machining, where the job shop soaks them in WD-40. After this the parts are then shipped off to be nickel plated. The plater has stated that the WD-40 is difficult to remove and takes up to three days soaking for the part to be clean.
Parts still comeback to us with oxidation on the surface and in the threaded holes. We've gone back to the plater and the job shop to discuss this issue. This has turned into a round of finger pointing. The plater blames the job shop for plating interference caused by the WD-40 and requests that they be soaked and shipped in cutting fluid. The job shop states that they no longer use WD-40 and have switched to the cutting fluid and that the plating company is to blame, stating that they must have left the parts out of the cutting fluid for to long.
We're looking to bypass the entire blaming process and are looking to use a stainless steel alternative.
Property wise is a 304 or 303 steel compatible with 1020 steel?
RE: 1020 Steel alternative
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
If the parts are small and thin walled ,303 might pose a cracking problem at times. This is just a piece of caution..
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
I don't think the cutting oil is the way to go while some may work others should be removed as fast as possible from a machined part.
ht
Maybe the plater needs to test its wash bath, sounds like they might be trying to save money by running a depleted tank. Have you tried another plater?
Replacing the WD-40 with a rust inhibitor still adds the step of removing the inhibitor before coating. I heard good things about Fluid Film but I'm not familiar with how difficult it would be to remove completely from the part.
The parts MUST go through a cleaning operation prior to plating regardless of what type of rust inhibitor is used, so the only issue is one of compatibility: can the rust inhibitor/coating film be satisfactorily removed by the cleaning process used by the plating company. It is difficult for me to believe that it takes 3 days of immersion in a proper cleaning bath to remove the dried film from WD-40, but that is probably a topic for another discussion. It should be very easy to verify that machined parts with cutting fluid only can be cleaned and plated with no defects. Has this been done?
