Polyline Fill on Xref
I have an xref file that has plines with a thickness. On the original file, the plines show up as solid lines with thickness, when I use this file as an xref, the plines do not show up as filled, only the outer edges and a centerline show up. Fill is "on", and I checked most things I know to look for. Does anybody have a fix to this problem?
RE: Polyline Fill on Xref
I think your problem caused by one of the two below reasons.
1. The SHADEMODE is set to "Hidden" or "3D Wireframe".
2. The view direction is not perpendicular to pline's plane.
Farzad
