Delayed cracking of 200 series stainless steel
all this talk of saucepans made me wonder if anyone had any information on the delayed cracking of 200 series stainless steel.
this is something that can happen to 200 series deep drawn cookware (usually but not exclusively the 1% nickel grades rather than the traditional AISI 201/202 types)
i found the following -
"New 200-series" steels:
An opportunity or a threat to the image of
stainless steel?"
and
THE NEW 200-SERIES : AN ALTERNATIVE ANSWER TO NI. SURCHARGE ?
DREAM OR NIGHTMARE?
I need to know a lot more about this effect - i tend to assume delayed cracking is a mechanism akin to SCC ??
I will probably be 'pestering' the steelmakers and see if i can find other sources, but if anyone can help at all I would certainly be most grateful.
Materials technologist/metallurgist
RE: Delayed cracking of 200 series stainless steel
If the material is stable enough to stay non-magnetic then the cracking must be from CSCC.
Plymouth Tube
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
Plymouth Tube
Michael McGuire
Delayed fracture of metastable austenitic stainless steels due to hydrogen interaction with deformation-induced martensite has been documented in some journal articles, etc. Here is a very recent one:
Hydrogen-induced delayed cracking in the AISI 301 unstable austenitic steel sheet
http:/
Here is a Google Scholar search. I used "delayed fracture" as a keyword, but there will be more hits using hydrogen embrittlement:
http:/
thx guys
how dumb am I, I never even heard of Google Scholar !
""There isn't much published on this topic, but I can tell you that austenitic stainless steels behave very similarly whether the austenite is stabilized by manganese or nickel.""
but the 1% nickel grades are the more prone to cracking, regardless of the amount of manganese content to stabilize? and the 4% Ni grades are far less prone but more prone than 18/8.
(although that seems debatable - the doc attached i just found has a 4% nickel grade with same risk of delayed cracking s 18/8, although it does have copper to lower work hardening rate)
so is there not a relationship between the nickel content and the risk of delayed cracking/cold cracking?
it appears there is a limit to the amount of manganese or nitrogen content to stabilize and there should always be at least some nickel content?
i will need to do a bit of studying but not for 2 weeks, I'll be on a beach in Turkey soon....
A 200 with 1% Ni, enough Mn, and a boat load of C (0.08%) and N (0.25%) will be stable when cold worked, and it would reach real high strength.
I have never seen a 200 that didn't form a lot of martensite on cold work. They really are metasable alloys.
Plymouth Tube
