When changing units, model disappears
When I try to change the units (i.e. the default units are mm and I want to change it to inches) on an imported iges, or step file, the model disappears. I tried redrawing/regenerating and nothing. Anyone have any ideas?
Thanks in advance.
Thanks in advance.
RE: When changing units, model disappears
If model tree consists of the features then it should be visible....try & check ur visibility settings in view mode.....
Just a thought and hopefully it works out.
- J -
Save as step
Open as prt
change unit
Look
Wildfire is very nice, if you know,
how work with him
