API Spec 7 geometric tolerance for shouldered connections
I represent connections in drawing with reference to API Spec 7.
But I confused a little because did not find info or skip it regarding to geometric tolerance for shoulder.
If shoulder surface is critical for joint what's about secure Box interface and move it inside about 5mm from practical side.
I would appreciate if anyone enlighten this points with API Spec 7.
I have found requirements for shoulder surface in Russian GOST. It is stated perpendicularity no more 0.1mm to thread axis and flatness no more 0.07mm
But we work with API standards only.
RE: API Spec 7 geometric tolerance for shouldered connections
You will now find the requriements for rotary shoulder connections in API Spec 7-2 (ISO 10424-2). Specifically, 7-2 requires the shoulder contact faces to be in a plane and square to the thread axis to within 0.05mm (0.002 inches). This is the same requirement that was found in sections 10.2.1 - 10.2.2 of the 40th edition of API Spec 7.
rp
Concerning to protection shoulder for box thread. Is there something rational in this idea from points of drilling operation or it is impractical to protect this sealing surface with such design?
Can you ask your ask your quesiton using different wording?
rp
As I understand now during transportation to rig tubing ends protected with plastic caps. When tubes make up at rig it is not so useful because wipe and clean flat surface much easy then stepped. Anyway I would appreciate if someone add additional pros&cons to my 1-st idea with protect design.
The problems with your design is that it is customary to have the OD of both members match. With your drawing, the OD of the male connector would have to have a smaller OD to fit the recess of the female side. With the male connector being smaller in OD, you are sacrificing bending strength.
rp
