Jiggling Assembly
Jiggling Assembly
Sorry for the vague title, I don't even know what to search for for this issue.
One of our guys has got an issue with a large assembly. When the view is rotated, parts are jiggling about, like an earthquake. It's a difficult thing to describe, sorry. Parts are shaking against each other as the view is rotated and it's slowing things down.
The assembly is fully defined and when finished rotating, all the parts are where they should be.
RE: Jiggling Assembly
What are the computer specs?
Intel Xeon Quad @2.27GHz
12GB Ram
Nvidia Quadro FX580
Windows 7-64
Have you tried adjusting the Tools > Options > System Options > Performance settings?
we've tried different level of detail performance settings, are there any other settings that could make a difference?
Is the graphics driver on the "slow" machine, SW approved? (Should be 8.16.11.9187)
http://w
Are other programs/utilities/processes running on the slow machine?
You could use the Copy Settings Wizard to copy the settings from your machine to the other one. Make sure to create a copy of the settings from the slow machine before applying yours though.
The graphics driver is the latest one, not the solidworks approved, so I guess this would be the first thing to try. Our IT dept are reluctant to install older drivers on our machines though.
The only other things that are running on that machine would be outlook and maybe a couple of explorer windows. It's done it consistently ove a couple of days with a restart in between.
I'll give the copy settings wizard thing a go if the user wants to.
Open up the 3Dconnexion Control Panel > Device Configuration > Calibrate.
Cheers,
Anna Wood
SW2011 SP4, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
I'm wondering if it is to do with graphics card RAM. This machine has a 512 card, but we've had all sorts of issues here on machines that are running 256 cards
Did you try my suggestion?
Cheers,
Anna Wood
SteveJHH please give us the specs of the machine you are troubleshooting. My signature can be guidance for what is necessary for us to know.
Remember to practice good FODLAR when requesting help for this sort of thing.
F= Frequency--How often are the problems occurring?
O= Onset---When did the problems begin?
D= Duration--How long have the problems lasted?
L= Location--Where do you notice the problem?
A= Association--Is there anything else related to the problems or problem?
R= Relief from problems--Does anything help relive or diminish the problems or problems?
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
TOP
CSWP, BSSE
One other user here has had something similar happen recently, and he is the only other user with a space navigator, so I suspect that is the cause.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
TOP
CSWP, BSSE
