Momentary switch on/off feature
Hi everyone!
I've started to learn PLC programming (Simatic manager with plcsim). I red an interesting lesson on the internet: write a plc program which can toggle on and off an output (LED, motor, etc.) with and ON and OFF momentary push button. I could solve it with an SR flip-flop, but the next lesson is harder for me. It's the same with only 1 button.
So, at beginning i push the button (then release it) and the output turns on, till i push the button again, when the output turns off (and then if i push again, it will turn on, then push again, it will turn off, and so on).
I know how to program it in C language, here it is:
if ((in1==1) && (temp1 == 0)
  temp1 = 1
  outTemp = !outTemp
if (in1 == 0)
  temp1 = 0
out1 = outTemp
The problem, that it's complex for me to program it in STL/FBD/LAD. Can someone help me with that? I know, I should make a latch circuit (with one or more flip-flops maybe), but I don't really know how :S
And my other question: is there and easier/better way to solve the first circuuit (i solved it with 1 SR-FF, and i think it's the best/fastest solution)
 szfAmman
RE: Momentary switch on/off feature
You can increment a counter on the positive edge of the pushbutton press signal.  Then compare if the counter value is odd/even.
Don't even need to evaluate. Just let bit 0 be your output. It changes state each time the counter steps up.
Gunnar Englund
www.gke.org
A number of PLC's allow the internal coils to work in an inpulse mode, where the coil state toggles with each rising edge input to the coil.
Hi Guys,
I have the same problem as the original poster. I fully agree that the solution with the counter and 0 bit is smart. However, I was asked to solve it just with contacts and simple outputs. Could somebody post a solution of this task in Ladder please?
I just found it on plc net, sorry for silly question guys :)
