Running analysis
Running analysis
Running analysis
Hello. I am ETABS beginner. i just want to ask why is that when Im already through with my models, loading,etc and then when i run analysis the result is incomplete analysis..above it says that exceeded memory by 3483652kb.......pls help me on this..thanks
RE: Running analysis
You probably have a very large model with extremely fine mesh. You may have exceeded the number of equations that can be solved by the program.
Thanks slickdeals..can i send u some of my models and check whats d problem on my model..i just follow some tutorials in youtube and attach tutorial on etabs thats why i find it hard for me to start..can you send me also sample of finished product in your own from etabs..thanks..i highly appreciated your response..
Upload the .e2k file
