Antenna with different receive and transmit impedance
generally, by design, the receive and transmit loads of an antenna would be the same. Is there a way to have differing loads in transmit and receive modes?
I.e. I want an antenna to be highly reflective to incoming signals but be ideally parametrised when transmitting.
Thanks for any suggestions or help
Cadour
Cadour
RE: Antenna with different receive and transmit impedance
In answer to the original question, you'd probably use a simple T/R switch at the feedpoint. When transmitting, the transmitter would be connected straight through. When not transmitting, the "receive" path would be a refective short.
There may be other techniques that could be used such as circulators or quarter-wave directional couplers.
What these all have in common is that the action happens in the feed line, not the antenna as such.
TTFN
Chinese prisoner wins Nobel Peace Prize
Interesting that Plasma antenna- what a brilliant idea (litteraly).
