ADD LIST OF POINTS FROM AN EXCEL SHEET
Is there a method of importing an Excel sheet that has point coordinates into a NX 7.5 model where the points are automatically added to the NX model?  Any help would be appreciated.
RE: ADD LIST OF POINTS FROM AN EXCEL SHEET
Probably best to ask on the NX forum !
Solid Edge would not be able to do it, although you can generate a curve directly from the points.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
I can not give informations about the import of points in to NX.
 But if you talk about a point cloud with some 100.000 or millions of points it is better to use a tool that creats a JT-File or othe CAD-Formats that you import to you CAD Application.
