Double angles with y-axis bending
I have a case where double angles are used as compression members (braces). However, they are picking up some wind loads causing bending about the y-axis. AISC doesn't specifically address this situation if Chapter "F". Any suggestions
RE: Double angles with y-axis bending
This basically means using Mp or 1.6*My as the nominal capacity.
