Stronger then 7075-T6 for car axle
My friend has a machine shop so I can easily have access for his labor of making some parts of my toy.
I have a transmission axle made by 7075-T6 and it last about 40 hours of running. I want to use something stronger but easy on machining. I checked around, this 15-5 PH Stainless Steel Condition A (annealed) is very strong almost double then 7075-T6:
Ultimate Tensile Strength, psi 161,000
Yield Strength, psi 140,000
The more stronger material the longer last of the axle. But I want something easier to machine or may be something less stronger then heat treatment after machining. This would work too.
My goal is to find a material that can last 60hours of running or say 1/2 stronger then 7075-T6. What do you recommend? This is just for my toy. Nothing needs engineering calculation. Thanks a lot.
RE: Stronger then 7075-T6 for car axle
thread330-21337: 1144 Stressproof
Mike
Mike Halloran
Pembroke Pines, FL, USA
