Metric Thread Callout in Drafting
I am trying to use the Feature Parameters function to call out Metric threads. But it only shows, for example M6, and not the pitch.
How can I get it to show M6x1.0?
RE: Metric Thread Callout in Drafting
Make sure that you're actually selecting the 'Thread' feature.  Also what 'Standard' are you using?  Try 'ansi_mm'.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
But it's grey, the ansi_mm. How can I activate it? Some file I need to install?
Many thanks!
It's available on my system.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Not on mine
Are you by any chance creating a Metric threaded-hole in an Imperial unit part file?  Or perhaps creating a Drawing of a Metric piece-part model, but using an Imperial unit Drafting template?
As best that I can determine, the base units of the Drawing file will determine which Dimensioning templates can be used to create the feature dimensions of something like a Threaded-hole.  If the Drawing file is an Imperial units part file, then only the 'ANSI' template will be available.  However, if the Drawing file in a Metric unit part file then you will have access to the various Metric-based dimensioning templates, which includes 'ansi_mm', 'iso_din' and 'jis'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Is there anyway I can use ansi_mm in an imperial template?
Not that I'm aware of.
The way this works is that the 'template' files (which are special NX part files found in what we call the 'inh' folder) are loaded into your drawing file and they carry the formatting examples which are used as the actual templates for whatever type of hole feature that you've selected.  The issue is that the 'inh' file selected has to be of the same units as the Drawing file, and we've only supplied one Imperial units file, covering the ANSI inch standards, and 3 Metric unit files, one each for ANSI, ISO and JIS metric standards.  Unfortunately these files, while they can be opened like any other NX part file, the actual template objects can NOT be edited or changed by the user and yet have them remain valid usable.  That must be done by development using special software.
That being said, I would highly recommend that if you wish more coverage of other situations, that you contact GTAC and have them open PR's to cover this lack of coverage (they will probably be converted in ER's but at the moment that may be just as good).
John R. Baker, P.E.
Industry Sector
Cypress, CA
Convert inh template files to either metric or imperial file using a utility called something like ug_convert_mmtoimperial
NX 7.5.2.5 mp2, TC 8.3
The 'template' parts John is referring to are different from the seed parts or template parts used to make new files. The utility ug_convert may have some unintended consequences. Backup your files before you experiment.
