Reference Sets
Reference Sets
Is there a way to "Lock" a reference set. I have a large assembly that I am linking geometery to in several parts. I have my "Part" reference set but when I make it my work part it goes to "entire part". I have always delt with this I was just wondering if there was a way to "Lock" it in so when I make it the work part it stays on whatever I choose the locked ref set to be. If this is not available will Siemens consider adding it in the future?
RE: Reference Sets
A refernce set ONLY applies when the part is used in an assembly. The assembly will only see the components that you have specified in the specific reference set. When you make that sub-assembly the work part, it will always revert to the full assembly.
Ben Loosli
RE: Reference Sets
Display using 'Entire part' Reference Set. Uncheck it.
Make sure you do this on site level and lock it if you want this for all the user.
Don't forget to restart NX.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
RE: Reference Sets
NX 6.0.5.3 (NX 8 Beta)
Windows XP32 (Windows 7 64)
RE: Reference Sets
