mechanical seal
mechanical seal
i have problem with a centrifugal pump used as oil circulation pump for oil condenser it is fitted horizontal. once i stopped pumping vapor inside the oil condenser,the pump start to leak and i do not know the cause of this.
RE: mechanical seal
Let your acquaintances be many, but your advisors one in a thousand' ... Book of Ecclesiasticus
RE: mechanical seal
Need to provide more info such as oil properties,pumping temp, pressure, static pressure in the condenser , seal configuration etc.
RE: mechanical seal
