Calculating minimum bend radius of Composite rod
Hello
Is there a standard methodology for calculating the theoretical minimum bend radius of composite rod. I have a spoolable 10 mm dia rod and I want to know what the minimum drum diameter that i can spool it onto is.
Ultimately I want to use this formula to run a numerical optimization to find the best overall stiffness (changing the diameter of the rod, and composite mixture/material) when the rod is in a pipe bore, so any info on buckling calculations for composite is also very useful to me.
Thanks in advance
Thanks in advance
RE: Calculating minimum bend radius of Composite rod
It's probably safe to use Euler buckling for a composite rod. Stress for buckling = pi^2*E*I/L^2. (I for round rod is pi*D^4/64.)
For UD ordinary carbon at a fibre volume of 50% E is about 100000 MPa (14.5 Msi). UD glass is maybe 35000 MPa (5 Msi).
Maybe it's that Friday feeling, but i don't see where you get the 500 (well 499.5) ratio of rod diameter to bend radius. The manufacturer has quoted a minimum bend radius of 1.4m. perhaps this is empirical based on low cycle fatigue or something though. Your info has pointed me in the right direction though, as we want to be able to play around with the numbers ourself to find the youngs modulus (or carbon fill), rod diameter, and also the grade of carbon that we are using
For a 10 mm rod and an IBR of 1.4 m I get 3560 microstrain and maybe 15 or 20 MPa in UD glass or 400 MPa in carbon, which sounds passably safe for repeated application with glass.
[What little data I've got for glass in fatigue gives a max tensile stress of 20 ksi (137 MPa) for a life of 10^8 cycles...however, that corresponds to a strain of 0.68% according to them (Sandia report for wind energy, SAND92–7005), which seems to give a bit of a low E for UD E-glass, though the claimed fibre volume fraction is also low (30%).]
For a sane number of winding on of 1000 times the Sandia stress was 45 ksi. Say a factor of one and a half for scatter (a guess) and another one and a half for 0+-P not P+-P loading (a real guess) gives an allowable bending stress of maybe 20 ksi again. 1.4 m doesn't look daft.
I've got even less info on UD carbon in fatigue than glass. What I've got indicates fatigue strengths of at least 80% of the static strength, about 600+-600 MPa in compression. That's a maximum failure strain of about 8500 microstrain.
Say a strain of 4000 microstrain, that implies an inside bend radius of 1.2 m. As I said, their 1.4 m would give a strain of 3600 microstrain. It's possible that the limits for static strength in damaged carbon are more important than fatigue, even for a civil structure like this.
Someone else might have a more realistic estimate for bending fatigue allowables in carbon.
