Centrifugal Compressor Thrust Bearing Jacking Oil
Working on an overhung centrifugal compressor, and come to find out the OEM has a "jacking oil" system (giggity), which feeds high pressure (2000 psi), low volume ( 0.5 gpm) lube oil to, what looks to be just one side of the thrust bearing, and only during start-up and shutdown.
We have a couple different other brands of overhung compressors which are quite mechanically similar to this one, and they have just normal lube oil supply at pressures less than 100 psi.
The only thing I can figure is that with out the aid of a balance piston in the overhung design, that the high pressure oil is there to supplement the oil film at low shaft speeds until such speed is reached that the hydrodynamic oil film can develop with normal oil supply conditions.
However none of the other designs has this system, and am wondering if this most likely a knee-jerk design consideration after a incidident involving or due to a failed thrust bearing.
Anyone have any real knowledge about why such a system may have been put in service?
RE: Centrifugal Compressor Thrust Bearing Jacking Oil
Johnny Pellin
22,000 hp, VFD driven synchronous motor, 1800 rpm, with speed increasing gear box, with compressor speeds up to about 8300 rpm.
process conditions are generally 500 to 600 psig suction pressure, and 700 to 800 pisg discharge pressure, with 0.6 SG natural gas.
We have several other machines by two other manufactures, which are very similar to this one and operate at pretty much the same process conditions, and none of them have this jacking oil system either.
Whatever the reason, we're going to re-install and re-use this system.
