Need Microsoft Excel 8.0 or Higher
I am trying to use a sheet metal gauge table. Whenever, I select a table, I receive an error saying that I need Excel 8.0 or higher installed. I have Excel 2010 installed. Does anyone know how to fix this?
RE: Need Microsoft Excel 8.0 or Higher
Now, wasn't that was obvious from the SWX message saying you needed "Excel 8.0 or higher"?!
I've had occassional problems with Design Tables. I go to edit the table and get some goofy message saying it was created in Excel 2.0 and there is a compaitibility issue - - WTF?! The DT was created within the last week and the file runs fine, I just cannot get into the DT to edit it!!! The only solution to this is to blow away the DT and recreate it. How nice!
- - -Updraft
