Edit in assembly context
it's possible to edit a sheet metal part in assembly context without see the entire part ?
For example, if I edit a part in the assembly context, the flat pattern is shown.
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
RE: Edit in assembly context
Did you try using layers to hide the flat pattern ?
Didier Psaltopoulos
http://www.psi-cad.com
I'm using NX7 and maybe you aren't aligned to the new method to create flat pattern (solid).
New method use reference set to hide FP not layer and sincerely I don't like layer.
Thank you...
Preferences -> Assemblies...
...and the 3rd item in the dialog, 'Display as Entire Part', should be toggled OFF. If not, then do so.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
When I edit in the assembly context with the option unchecked I didn't see sketch entities.
There are others options to set ?
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
