Impacts of an earthquake on hangers
I currently study seismic effects apply to a piping structure with spring hangers. I would like to know, what are impacts of an earthquake on these spring hangers. Here are my questions:
1) What are, in "hanger report W/ Text", "vertical movement" and "horizontal movement"?
2) Do these values vary according to loads applied to the structure studied like uniform load?
3) In "hanger report W/Text", "maximum table displacement range" concerns the maximum displacement vertical? Horizontal? Or both?
4) What are, in "hanger report W/ Text", "minimum allowed single spring load" and the "maximum allowed single spring load"?
5) How can I know if hangers will stand up to the seismic load? Is it just to compare the displacement at the node connecting piping and hanger with "max table displacement range"?
RE: Impacts of an earthquake on hangers
2) Yes.
3) Vertical, and this is the maximum value from the table as a while, not for that one spring.
4) The load limits for that spring - from the hanger table.
5) Yes.
Richard Ay
Intergraph CAS
I would like just a detail about question 5):
For the node where there is the hanger, the comparison is well possible between "Displacements" in "standard reports" and "max table displacement range" in "hanger report W/ Text"?
Popey130
The maximum table displacement is the largest travel value from the entire table.
Richard Ay
Intergraph CAS
In fact, I don't understand well the difference between the two... Normally, she should be the same value, no?
Popey130
Richard Ay
Intergraph CAS
