Die casting aluminum info.
Hi people.
i would like to know, if someone could help me with some info about die casting aluminum:
- what is the shrinkage of aluminum?
- how big should the draft angles be?
- how about the size of the runners and gate(s)?
im goind to die cast a part which volume is equal to 17.6 cubic inches.
RE: Die casting aluminum info.
It will not be possible to provide text book inputs like shrinkage of aluminium,,draft angles or relief or the size of rigging systems without knowing,if it is a permanent mold casting or a high pressure die casting,etc.
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
