LED DRIVER IC HELP
LED DRIVER IC HELP
I was wondering if someone could take a look at this LED Driver I am working with and tell me how the Control Inputs are used. They look like simple on off inputs but I don't know if they are routed to ground to be on, or you need a voltage input to trigger the on off.
I attached the cut sheet with the diagram on it. The CTL 1, 2, 3 are what I am looking at.
Thanks in advance
Tim
http://www.diodes.com/datasheets/AL3159.pdf
Thanks in advance
Tim
RE: LED DRIVER IC HELP
Keith Cress
