Arc Gear Testing
Arc Gear Testing
Arc Gear Testing
"I aplogize for not being very much specific in the information here."
I need some input into understanding my responsibility as an  engineer and vendors responsibility who is supplying the equipment.
I am planning to buy a arc rated switchgear for a "X kV" voltage. For testing requirements, vendor is supplying a report by a testing company for "Y" kV arc rated test and assuring me that he will use the same cell for "X" kV application and it would work.
X voltage is smaller than Y.
Vendor  has  a test certificate for "Y" kV level but not for "x" kV.
How do I decide that it will work for new smaller "X" kV arc rating, if same cell dimesions are used.
Any suggestions ?
RE: Arc Gear Testing
Are talking about something like 12 kV system and 15 kV gear? This would not normally be a problem.
