Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This is easily the most helpful website I've ever used, and this is the best forum with the quickest response time bar none...."
Geography
REDesigner09 (Aerospace)
8 Jul 11 13:48
  I have a couple of reference pins that I have in the same part file - in this case, the turbine blade file.
  I've been instructed that doe to ProE WF 4.0 (or all versions), that ProE cannot have 2 or more solids in the same file & still be able to control the layers to hide / unhide in desired drawing views.
  Therefore, I need to make these pins as Surface representation.  However when doing this, I was not able to select desired end faces or cannot trim the elongated pins to the desired end faces of the turbine solid.
  Please provide instructions....
Close Box
Join Eng-Tips® Today!
Join Us             Close
