Alternative SW Toolbox?
Anyone got a location I can download a new Toolbox? I couldn't afford it, but I really need a standard parts library for faster modeling.
Any suggestions for free ones? or at least a cheap, usable SW2011 compatible one?
RE: Alternative SW Toolbox?
Many people have created their own library.
For now, I've gone back to making my own library of standard parts using config's driven by a design table. That's not really how I want to do things though...
I'd be keen to know how you progress on this one!
I'll give 123GO a try, I just got the confirmation email.
"cheap at twice the price"
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
"I downloaded your software a few days ago and have now used it during the design of my latest piece of equipment. I have been very impressed so far!
I am now creating drawings of the machine. Some parts of the machine have been created using configurations and these have different names, so that they appear as separate items in my BOM, which is as I want. I need the fasteners to group together (i.e. I have used 3xM8 washers in three areas so I want a total of 9 M8 washers to appear in a single row of the BOM). Unfortunately, it seems that for each use of the washer, the software has created a new config. with a different name. This makes it hard to group the washers together. Is there a way of grouping the washers (or any other fastener) in the BOM?
Thank you in advance for your help!"
Any ideas?
- 4 off M8x30 CSK head screws with a nut and washer
- As above in a second location
- 4 off M8x16 hex head screws with washers
I set my BOM to display config's with the same name as one item and the CSK heads have come together as total 8 off in one row. Perfect. The washers, however, have been created as new config's for each batch generated: effectively, I've done three operations, which has generated three config's with different names...
That lot made perfect sense in my head, but I'm no teacher so if it's gobbledegook to everyone else, please let me know and I'll try to clarify haha!
Hello Tom,
You're right, I've been able to reproduce what you're describing.
I don't know if it's the normal behaviour (maybe come customer request), or if it's a bug, but I've reported it to our development team.
Anyway, here's an easy workaround that you can try:
1) rigth-click the 1st washer of the second (or third...) series of washer (it's better to select it in the FeatureManager tree),
and select Component properties...
2) Then select the configuration of the 1st series of washer (for example 16-1.5), and click Ok.
The patterned washers of the same series will automatically updated.
You have to this action for each series of washer (if you have 3 series, you have to do it 3 times).
3) After setting each series with the same configuration, you can clean-up the washer component : open it and delete the unused configurations.
4) When creating the BOM, you'll find only one row for the washer with the right quantity.
Inconvenient of this method : if you have to edit the fastener with 123Go (select it and click Logopress3, 123Go by Logopress3), it will re-recreate a new configuration, but you can easily repair it as described above.
