Help Importing Part File without drafting wireframe
Running NX 7.5.2 Windows XP Pro 32 bit
I think this is an easy fix, but I'm not sure where it is. I am importing another NX 7.5 part file, but every time I do I get the drafting title block with it. What options do I have to change to import the actual part without the drafting wire frame.
RE: Help Importing Part File without drafting wireframe
For example, if you are just interested in getting 1 solid body (with parameters) into a new part go to File -> Export -> Part... choose the part to export to, the solid to export, and make sure the retain internal parameters and copy if referenced options are chosen. After you press OK and the magic happens, your chosen file will contain the desired solid body (along with all the entities used to create it).
When you export a part, as Cowski suggested, you have the option to choose which objects you want to export and which you don't. You also have the option of choosing whether or not the geometry that you export will be parametric or "dumb" and to what extent.
So import a part if you want it ALL. Export a part into an existing file if you want the flexibility to choose.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Or maybe just your longevity with using UG/NX.
In today's world, the master model approach is best for keeping the various aspects of the total design segregated.
Ben Loosli
