NX7.5.2 Adding/Replacing Component and RMB
I am having an issue with adding/replacing a component within an assembly.
I have tried with the reference set to "Empty" as well as it set to "Part".
I have also tried to substitute.
And in all of these attempts, without warning it closes NX7.5.2.
And after rebooting I now cannot use my third mouse button in the Assembly Navigator.  If I 2xclick on a component it will make it the work part, however, when I try and right mouse button there is no longer a drop down menu.
RE: NX7.5.2 Adding/Replacing Component and RMB
If NX is crashing ("without warning it closes") then please contact GTAC as this is the sort of thing which only they will be able to help you with.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
