Rotate curves
Rotate curves
Is there a way to rotate a curve? Say I want to rotate a curve drawn flat on the x,y plane and I want to tilt or rotate it to a desired angle later on the z plane?
Thanks!
Hockeyguy
Thanks!
Hockeyguy
RE: Rotate curves
If so, the answer will depend on what type of curve it is.
Sketch curve: if the sketch is on a model face or associated datum plane you will have to reattach the sketch to a new plane. If the sketch is on a fixed datum plane you can move the datums and the sketch should update (depending on what you constrained the sketch geometry to, some editing may be necessary).
Associative curve: moving this type of curve will depend on what it is associated to.
Basic curve (dumb curve): use move object to move/rotate it at will.
