Balloon ID Seach in Drafting
I am using NX6.0.2.8 MP7,
I have an Assembly contains nearly 1600 parts and the balloons Id(Call out) is created manualy by 'Id Symbol' for all the parts.
I need to search the "Balloon ID" by entering the balloon ID number and
I need to know, how many times it present in the same drawing sheet.
Is there any possibilities to do this? if any one has any utility please share it?
(Already i raised this query in GTAC,but No Solution)
Thanks in advance,
Suresh G
RE: Balloon ID Seach in Drafting
You'll need some sort of custom NX Open-based program to accomplish something like that.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
http://www.plmworld.com/museum/
I hope this will help to you. Only you must create an array to collect the different id symbols.
Imports System.Collections
Imports NXOpen
Imports NXOpen.Annotations
Imports NXOpen.UF
Public Class report_all_id_symbols
    ' class members
    Private Shared theSession As Session
    Private Shared theUI As UI
    Private Shared ufs As UFSession
    Private Shared lw As ListingWindow
    Public Shared Function Main(args As String()) As Integer
        theSession = Session.GetSession()
        theUI = UI.GetUI()
        ufs = UFSession.GetUFSession()
        lw = theSession.ListingWindow
        Try
            Dim idCol As IdSymbolCollection = theSession.Parts.Work.Annotations.IdSymbols
            Dim ids As IdSymbol
            Dim iEnum1 As IEnumerator = idCol.GetEnumerator()
            iEnum1.Reset()
            While iEnum1.MoveNext()
                ids = DirectCast(iEnum1.Current, IdSymbol)
                lw.Open()
                lw.WriteLine(vbLf & "Symbol: " & ids.Tag.ToString())
                Dim idsb As IdSymbolBuilder = idCol.CreateIdSymbolBuilder(ids)
                lw.WriteLine(" Text: " + idsb.UpperText)
                lw.WriteLine(" Origin: " & idsb.Origin.OriginPoint.ToString())
                Dim lb As LeaderBuilder = idsb.Leader
                Dim ldl As LeaderDataList = lb.Leaders
                lw.WriteLine(" Number of LeaderData: " + ldl.Length.ToString())
                For i As Integer = 0 To ldl.Length-1
                    Dim ld As LeaderData = ldl.FindItem(i)
                    lw.WriteLine(" LeaderData No." & i & ": " & ld.ToString())
                    lw.WriteLine("  Stub Size: " & ld.StubSize.ToString())
                    lw.WriteLine("  Stub Side: " & ld.StubSide.ToString())
                    ' Perpendicular as of NX7
                    ' lw.WriteLine("  Perpendicular: " + ld.Perpendicular.ToString());
                    lw.WriteLine("  Arrowhead: " & ld.Arrowhead.ToString())
                    Dim selection1 As DisplayableObject
                    Dim view1 As View
                    Dim point1 As Point3d
                    ld.Leader.GetValue(selection1, view1, point1)
                    lw.WriteLine("  Leader view: " & view1.Name)
                    lw.WriteLine("  Leader view type: " + view1.GetType().ToString())
                    lw.WriteLine("  Leader point: " & point1.ToString())
                    If( view1.GetType().ToString() <> "NXOpen.View" ) Then
                        Dim model_pt(2) As double
                        model_pt(0) = point1.X
                        model_pt(1) = point1.Y
                        model_pt(2) = point1.Z
                        Dim map_pt(1) As double
                        ufs.View.MapModelToDrawing(view1.Tag, model_pt, map_pt)
                        lw.WriteLine("  Mapped Leader point: X=" & map_pt(0).ToString() & " ,Y= " & map_pt(1).ToString() )
                    End If
                    lw.WriteLine("  Number of jogs: " & ld.Jogs.Size.ToString())
                    Dim jogs As SelectObject() = ld.Jogs.GetSelectObjectArray()
                    For Each jog As SelectObject In jogs
                        lw.WriteLine("  Jog: " & jog.ToString())
                        Dim selection2 As TaggedObject
                        Dim view2 As View
                        Dim point2 As Point3d
                        jog.GetValue(selection2, view2, point2)
                        lw.WriteLine("   Jog point: " & point2.ToString())
                    Next
                Next
                idsb.Destroy()
                lw.WriteLine(" Number of Associativities: " + ids.NumberOfAssociativities.ToString())
                For i As Integer = 1 To ids.NumberOfAssociativities
                    Dim assoc As Associativity = ids.GetAssociativity(i)
                    lw.WriteLine(" Assoc No." & i & ": " & assoc.ToString())
                    lw.WriteLine("  ObjectView : " + assoc.ObjectView.Name)
                    Dim obj As NXObject = assoc.FirstObject
                    If obj Is Nothing Then
                        lw.WriteLine("  FirstObject : null")
                    Else
                        lw.WriteLine("  FirstObject : " & obj.ToString())
                        lw.WriteLine("   Owning Part: " + obj.OwningPart.FullPath)
                        If obj.IsOccurrence Then
                            lw.WriteLine("   Owning Component: " + obj.OwningComponent.Name)
                        End If
                    End If
                Next
            End While
        Catch ex As NXOpen.NXException
            UI.GetUI().NXMessageBox.Show("Message", NXMessageBox.DialogType.[Error], ex.Message)
        End Try
        Return 0
    End Function
    Public Shared Function GetUnloadOption(arg As String) As Integer
        Return System.Convert.ToInt32(Session.LibraryUnloadOption.Immediately)
    End Function
End Class
