Linear&Rotating Pneumatic Device?
Looking for a double acting pneumatic device which both translates and rotates at the same time. The application is for being the device to be bolted to a machine then screwing and unscrewing a screw. The device would likely utilize a threaded rod of some sort and would be attached to the screw through some machined adapter.
Technical specs. are not available off hand and I figure any company making something like this would have a range of options. Any help would be appreciated.
RE: Linear&Rotating Pneumatic Device?
How about a tapping head?
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them.  Old professor
