Blind Bolts HSS
Blind Bolts HSS
Blind Bolts HSS
I am currently designing a deck for a residence (helping out a landscape architect) and he wants all of the connections hidden.  This ultimately means I will need to utilize blind bolts (because he does not want field welds).  I have very little experience with them as I typically use thru plates, seated connections, or thru bolts for tubes.
Can anyone point me in the direction of a good resource for allowable values (I am using AISC 341-05)?
RE: Blind Bolts HSS
Hollo bolts at Lindapter.com is one
RE: Blind Bolts HSS
There are several manufacturers.  AISC now recognizes and accepts the use of blind bolts.  But, there does not appear to be a standard.  You have to rely on the manufacturer strength and design information.  I have been forced to use them a couple of times.  I recommend specifying a specific product or company.
http://www.FerrellEngineering.com
