Transfer 3D surface from matlab to solidworks
I have very little experience with both matlab and solidworks so bare with me if this seems like a very simple procedure.
I was given a .mat file that contained multiple matrices, one m rows x 3 col of x,y,z coordinates, and an m rows x 3 cols of the node identity that I figure is for the trimesh of the surface that I need and I need to somehow pull this up onto solidworks so that I can 3D print the figure.
Any help would be very much appreciated.
Thank you,
Nelson
RE: Transfer 3D surface from matlab to solidworks
Can the x,y,z coordinates be exported to something excel can import?  If so, there was a SolidWorks macro floating around some time ago to import a point cloud.
-Dustin
Professional Engineer
Pretty good with SolidWorks
I managed to transferred the x,y,z coordinates to an excel file, but I'm not familiar with SolidWorks macro, could you tell me what it is/where can I can the software?
Thank you sir!
-Nelson
Which version of SolidWorks do you have? If it's Premium you have ScanTo3D which will import 3D points.
A Point Cloud macro can be downloaded from http://solidworks.cad.de/mm_24.htm
Thanks guys! I was finally able to generate a point-cloud on solidworks :) Now I just have to make it a mesh on SolidWorks, can anyone help me out on this?
Again, thanks for the help, this is a great community! :)
-Nelson
Save as STL?
