Eliminating a whirlpool
I am looking for an Idea as to how to possibly reduce or eliminate a whirlpool in a cylindrical tank that currently is driaining too slow due to this problem. (in the 700-1000 gallon batch tank size range)
RE: Eliminating a whirlpool
Go here:
http://im
And you will get an education on the thing called a "Vortex Breaker"
Best regrads
Morten
You can also use a floating vortex breaker if it is practical to have something floating on the surface of your tank. I have seen plywood layed on the top of the surface and attached to the side of the tank to keep it from spinning.
This can be the easiest fix if you can pull it off.
