Hot-tap on flexible hose
I'm from a pipeline background and normally, if we need to to install a tee or a valve, we perform a hot-tap which allows us to install a valve while there is product in the line and under pressure.
I have a similar situation with a flexible hose. It has a 2" ID and is rated to 1500psi, similar to a wire-braid medium pressure hydraulic hose.
Is there a way tap into the hose and install a valve while there is product (diesel) and a maximum of 15 bar pressure in the line?
A link to a product of a supplier would be appreciated.
Thanks in advance.
Thanks in advance.
RE: Hot-tap on flexible hose
Mike Halloran
Pembroke Pines, FL, USA
That is a really ridiculous question.
Have a good long think about it. I hope that you will realise why.
I want to safely tap into the low points of a very long hose, divided into pressurised sections by non-return valves, to drain fluid out of it. Once the fluid is drained, the hose will be cut into sections and disposed of.
I am obviously not talking about welding a tee onto the hose. I thinking some clamp arrangement that will allow us to safely tap and drain the line.
The steel wire in hoses is high tensile and so very difficult to cut through. Even if there was a device that could clamp around the hose, breaking into the hose would introduce a massive amount of debris to the fluid.
As the hose flexes, half of the rubber is in compression and the other half is in tension, it would be impossible to seal it.
There is one rule about modifying pressure hoses...don't do it!
Buy a new hose and some fittings and do it properly.
